SOLD!! Tremec TKO600 5-speed, road race close ratio
Midlothian, Texas
Worley
Anneliese
Midlothian
I bought this unit new, have had it in my cobra since new (2019), only 14,000 "gently used ;) " miles. This is the "close ratio" road race version with the 0.82:1 ratio 5th gear.
Asking $1500 obo, I am in the southern Dallas/Ft. Worth area. I can deliver to the TCC Spring Meet in San Marcos, April 3-7, 2024.
Overview:
  • The original 5-speed overdrive heavyweight
  • Up to 600 lb-ft. of torque capacity
  • Exceptionally light at just 99 lbs. dry
  • Multiple shifter locations & dual speedo pick-ups for extreme versatility
  • Robust 3-rail internal shift mechanism offers firm, positive shifts
____________________________________________________
Manufacturer's Part Number:
TCET-4617
Application:
Ford​
Number of Gears:
5
Input Shaft Diameter:
1.125 in.
Input Spline Quantity:
26
Output Shaft Spline Quantity:
31
First Gear Ratio:
2.87:1
Second Gear Ratio:
1.89:1
Third Gear Ratio:
1.28:1
Fourth Gear Ratio:
1.00:1
Fifth Gear Ratio:
0.82:1
Case Material:
Aluminum
Notes:
0.82:1 Overdrive. Designed for electronic or mechanical speedometers. Holds 5.28 pints of fluid. 600 ft.-lbs. torque capacity.
